Forum: Addons
Topic: Loop Out
geposted Thu 22 Nov 18 @ 2:57 pm
why is loop out effect not working proper like before
Yeah I'm also having a problem with loop out after updating
check the gui, everything works as expected here.
Its working fine id just like to know what mode parameter does. using mac btw
just some coloring or type of loop out ..
Can choose between fade, filter, step, no fade etc..
Just play around with it, and see what you like better
Hi and thanks for this great effect.
I have 2 question please:
1°) What does the third parameter do please ? (I tried to change it but did not see any changes form 0 to 100%)
2°) In script mode, I understood that length is set in first paramater, but as it is in percentage, how to make it match with beat counting please ?
Thanks in advance for your help and have a nice day ;-)
1 for fade types hp & lp it's resonance of the filter
2 see the fx gui, all dials are valued between 0.0 & 1.0, this case there are 8 values that can be picked by the dial so they're all 0.125 apart.
Great, that's all I need, many thanks for your help 👍
