I'm have a lot of trouble figuring out how to group both tracks on VDJ.
I want to have it where if I seek to a certain point in track #1, that the same will happen in track #2.
I use the "sync" feature for my mashups, and sometimes it takes awhile to find the sweet spot where both songs are synced. I don't want to lose the sync, when I try to play the songs from the beginning.
Hopefully I'm explaining myself clearly enough. Any help would be really appreciated!
geposted Sun 25 Nov 18 @ 6:24 am
You should use POI's then
Set a POI where you want to start your mix, and a POI where you want to end it. This way you won't miss the spot the next time you try to mix the songs.
Also you can even automate some tasks (e.g. when the track that's playing reaches a certain POI to start the opposite deck)
geposted Tue 27 Nov 18 @ 12:28 am
