Forum: Addons
Topic: Screen Grab
geposted Wed 28 Nov 18 @ 4:14 pm
hola saludos desde argentina .. este plugins Screen Grab funciona bien al principio y después cuando lo tenes en la pantalla 2 y queres mover para capturar otra parte no te deja hacerlo ..reinstalas el virtualdj y nada ,, la unica manera es volver a instalar el windows ... algo muy raro.. si alguien tiene es plugins y lo utiliza me comenta si tiene algunsecreto ? o esta mal el plugins ? saludos
English forum^^
You are right it is totally broken, in many ways.
Specially the "Show source" do not work (move or resize) out of .... the main window (any display)
For this one issue : window the main window, move it under the grab area
Now the "Source window" is movable & resizable again ^^
you can also remove file "native_Screen Grab.ini" from plugins/ or plugins64/ folder and restart VDJ in a way to make it run once again
EDITED: in fact video window, or any other VDJ window under "Show Source" enables the move/resize
even effect gui or settings .... as long as "Show Source" is the top level one
Updates?
