had to buy license for making my ns6 working with virtualdj. once installed and the special driver for ns6 installed most of the functions on the gear didn't work no more or react different. the screen from laptop don't show my ns6.
example: the bottom PFL above each slidder works now as a FX
the slidder on the FX section works as gain for the main volume
I can write here all the different malfunctions but that is not interesting .
Can anybody help me with this problem. is there somewhere a file to download that put all these problems correct. on screen I can change the skin but that does not solve the problem
geposted Sat 01 Dec 18 @ 4:43 pm
Here is how you should have it setup:
https://virtualdj.com/manuals/hardware/numark/ns6/setup.html
Make sure 'factory default' is selected as mapping in Options->Controllers.
geposted Sat 01 Dec 18 @ 4:50 pm
