Manual says left-click to save, right-click to delete. I left-click the saved loop slot and it turns blue (Deck 1 color) but then, when I right-click it, it just stays blue. The same method works fine with hotcues—left-click to set, right-click to delete—, what am I doing wrong?
geposted Mon 03 Dec 18 @ 5:22 pm
Right-click on the SAVE button works here, deletes the saved loop. Doesnt turn the loop off of course, but the saved loop (slot 1) is deleted.
If you use the "Saved Loops" Pads page ( https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html ) then you delete the Slot with long press on the Pad
geposted Mon 03 Dec 18 @ 10:32 pm
Got it, click-and-hold does the trick. For hotcues right-click deletes, click-and-hold does nothing. I can see the reasoning behind this design choice though. Thanks!
geposted Tue 04 Dec 18 @ 4:13 am
