I did get Direct X failed to initialize.
geposted Fri 07 Dec 18 @ 2:26 pm
You can manually download 4717 from https://virtualdj.com/download/build.html then
geposted Fri 07 Dec 18 @ 3:01 pm
everything was all good with build 4717 until opening tag editor with a wma file, I did 3 roll backs to previous builds and all closed immediately and restarted only when opening tag editor for a wma file. The songs themselves play fine. I converted one of the tracks to mp3 and opened tag editor with no issue, but same song in wma instantly closed and restarted vdj.
[youtube]https://www.youtube.com/watch?v=OOYtIveVUlg&feature=youtu.be[/youtube]
geposted Fri 07 Dec 18 @ 6:13 pm
4718 up, could you try if this fixes it?
geposted Fri 07 Dec 18 @ 6:39 pm
wow, that was quick, and yes it works , cheers Adion
geposted Fri 07 Dec 18 @ 6:42 pm
