I just bought a controller that was working when demoed on my laptop but since i got it home it dosent. loaded latest firmware,got a pro membership and still nothing.
it is recognised by the program and receives an audio signal but no midi control to lap top. This is my last option, ive done some research, i know about the int mix/pc mix and channel knob positions for proper set up. idont think all the lights are on either only blue. i also reset VDJ settings to factory. Any help would be appreciated
geposted Fri 07 Dec 18 @ 3:11 pm
When you power it up does it go through the light startup sequence? Mine lights each light up over a few seconds and is then ready to go. Here’s what it should look like:
https://youtu.be/jch9b9snlkk
USB cable is good?
Did VDJ notice it when first started up? You would have received a pop-up notice on your screen.
Edit: You should also read the hardware manual for VDJ:
https://virtualdj.com/manuals/hardware/denon/mc6000.html
USB cable is good?
geposted Fri 07 Dec 18 @ 3:28 pm
Also could be a USB conflict. Try usbdeview to uninstall unused USB devices and clear the ports.
geposted Fri 07 Dec 18 @ 3:41 pm
also ensure you don't have any other software running simultaneously, which may require access to the midi device - a DAW or light software for example.
geposted Fri 07 Dec 18 @ 4:32 pm
