Is there going to be a virtual dj 9 coming out
geposted Sun 23 Dec 18 @ 3:19 pm
And by that, next major version will be VirtualDJ 2019 etc..
And VirtualDJ 2018 is the update to version 8. And VirtualDJ 2018 gets updates that you can get automatically if you set autoupdate to "yes" in settings.
Latest version is always available from here:
https://virtualdj.com/download/
geposted Fri 04 Jan 19 @ 11:50 am[ selected best answer by Adion on Fri 08 Mar 19 @ 10:44 am ]
VIRTUAL DJ 9 RELEASE
DATE PLZZZZ
DATE PLZZZZ
geposted Fri 04 Jan 19 @ 11:29 am
VirtualDJ has changed name conventions, the latest version of VirtualDJ is currently named VirtualDJ 2018.
Selected as best answer geposted Fri 04 Jan 19 @ 11:50 am
You should create one for 32bit
geposted Thu 28 Feb 19 @ 9:08 am
Virtualdj has always been compiled to 32-bit, with the new version 2018
has been made 64-bit compatible and is also in public beta
geposted Thu 28 Feb 19 @ 10:05 am
Which of the virtual DJ that is the best for now
geposted Fri 08 Mar 19 @ 8:18 am
That's easy:
That's always the current one from the download section of this page
geposted Fri 08 Mar 19 @ 10:17 am
