the VDJ didnt get all the music that is on my itunes? how do i fix that? im not sure if they are or how it reads please help thanks
geposted Fri 28 Dec 18 @ 2:01 am
You normally have to add new music to vdj either by playing it, or by using the "add to database" feature
ITunes is a little different though. For instance it has it's own special folder. But iTunes also sometimes doesn't allow access to it's tracks or simply doesn't download them until it needs them. If that is the issue, there may be settings in iTunes that you need to change
geposted Fri 28 Dec 18 @ 6:44 am
Is it music that you have purchased, or just rented (Apple Music)? If it's rented then VDJ will not play it, because it's DRM protected.
geposted Fri 28 Dec 18 @ 7:59 am
