I am trying to make deck 3 the master deck when opening VDJ 8.3. I had been using the script: deck 3 masterdeck. It worked in VDJ 7. I think it worked for a while when VDJ 8 came out, but I am not certain. Obviously I am using the wrong script because it is not working now. Does anyone know what the right script would be?
geposted Fri 28 Dec 18 @ 10:37 pm
There is a bug in the current version when you try to set the volume of deck 3 and 4 in ONINIT. Deck 1 and 2 works fine
It should be fixed in next build
So it may be a bug related to that, that you are experiencing
Here is the post for it:
https://virtualdj.com/forums/226804/VirtualDJ_Technical_Support/Bug_found_in_v8_3_b4675.html?search=oninit&page=1
geposted Fri 28 Dec 18 @ 10:50 pm
Thanks. I will wait and see!
geposted Fri 28 Dec 18 @ 11:02 pm
