hi I am using a soundcraft ui12 with powered speakers and vdj8 any help with audio setup would be grateful.many thanks.
geposted Mon 07 Jan 19 @ 9:55 pm
Looking at the soundcraft ui12 it doesn't look like it has any built in soundcards
If that is the case, and you don't want to get a multi-output soundcard, you probably need to run in 2x mono external mixer mode to get the best result
That is the config that is described here at 8:50:
However you may want to watch the entire video to check out other audio config options
geposted Tue 08 Jan 19 @ 10:24 am
The spec on the website says it has 2 channel USB playback and recording i.e. just stereo in and out.
geposted Tue 08 Jan 19 @ 6:00 pm
I think that's just the capabillity to play tracks of a USB stick, and USB-to-laptop for master recording
I have a Behringer mixer than can do the same
As always: I could certainly be wrong, and really need to have all the hardware known to the world, so I can try and test these kind of things! My wife disagrees on that, though...
geposted Tue 08 Jan 19 @ 6:02 pm
Regardless, not much use for Virtual DJ :-)
geposted Tue 08 Jan 19 @ 6:07 pm
