does virtual dj support pre cueing ...and what's the importance on stereo to mono splitter
geposted Tue 08 Jan 19 @ 7:19 pm
So that you can hear one deck in your headphones, while the other is sent to master out?
Yes, all DJ software can do that
And that is often the purpose of a splitter cable. If you don't have a multi output soundcard, you usually only have the stereo output from you laptops headphones connection
The splitter cable then makes it possible to use this for 2x mono - 1 for master out, and 1 for your headphones
For more inspiration on audio configurations in VDJ, this may be relevant:
geposted Tue 08 Jan 19 @ 8:21 pm
