I have 2 radio shows a week and upload the finished 2 hour mix to mix cloud. Its real ball ache having to manual enter the track listing & time stamps into mix cloud. Mixcloud already have Serato, Traktor compatibility. Is there an easy way to import the play list to a file that's compatible with mix cloud? (i.e. Cue sheet).
Thanks in advance
Thanks in advance
geposted Mon 14 Jan 19 @ 1:12 pm
Yes, I do that all the time when recording mixes for MIxcloud
You simply enable recordWriteCueFile in the options (see below)
That creates a .cue file next to your recorded mix file when you record - ready for upload to Mixcloud as Cue sheet
geposted Mon 14 Jan 19 @ 1:47 pm
Thankyou for this. So do I have to record my mix through mix cloud in order for this to happen. As I broadcast my radio show through B.U.T.T. and that recorded the music and microphone?
geposted Mon 14 Jan 19 @ 9:27 pm
I record mine directly in VDJ, and then also get the Cue file. I then upload both to mixcloud
geposted Mon 14 Jan 19 @ 9:41 pm
Thank you for this!!
I never knew this was even possible!!
geposted Tue 15 Jan 19 @ 5:54 am
thanks again... so is there a way to put my microphone through VDJ rather than through my mixer? as I could record it through VDJ then and just broadcast through BUTT.
geposted Tue 15 Jan 19 @ 7:29 pm
