Hi I was wondering if someone can tell me what the best dj controller is to use with vdj pro 8 for gigs please at a reasonable budget for small gigs , parties etc thank you
geposted Tue 15 Jan 19 @ 9:19 am
There is no "best" controller.
It all depends on your preferences. And what they feel like in your hands.
geposted Tue 15 Jan 19 @ 9:39 am
What one works best for gigs parties etc with virtual dj thank you
geposted Tue 15 Jan 19 @ 9:45 am
They all work pretty well, thare aren't really any bad ones.
You have Pioneer RZX at one end and DJ2GO2 at the other end, MC7000 somewhere in the middle so it's just a case of finding something to suit your budget.
geposted Tue 15 Jan 19 @ 10:09 am
Thank you and all of these will work with vdj pro 8 thanks
geposted Tue 15 Jan 19 @ 11:59 am
See here for supported controllers: https://virtualdj.com/wiki/VirtualDJ8%20Controllers.html
geposted Tue 15 Jan 19 @ 12:05 pm
NAMM is just around the corner and there could well be some new controllers on the way (Denon have teased one).....
On the other hand, buying a controller that's already supported by VDJ is the way to go if you want/need to use it straight away.
geposted Tue 15 Jan 19 @ 5:34 pm
If I buy a pioneer Ddj-sr dj controller with serato on it can I still use it with my vdj pro thanks
geposted Tue 15 Jan 19 @ 6:46 pm
kradcliffe has already given you the link to the "supported controllers" page. You can also download the setup guides for any controllers you might be interested in...
geposted Tue 15 Jan 19 @ 7:35 pm
