is there a way to print or export the database, the play lists, or search results.
geposted Fri 25 Jan 19 @ 11:40 am
geposted Fri 25 Jan 19 @ 11:47 am
You could recurse your whole library and then export browser view and you will get a .csv file
The .csv file can be open with Exel, good luck !
How to recurse (rightclick on mouse):
Here you find the button (left corner):
geposted Fri 25 Jan 19 @ 11:53 am
