I haven't used my Reloop Touch for a few months , but now I want to play on it again . Unfortunately the Touch-screen doesn't work . I wanted to re-calibrate it , but my computer doesn't read any touch-screen , like it's not there . For the rest, everything works fine . Anyone got any advise?
geposted Tue 05 Feb 19 @ 8:45 am
Are you sure it doesnt react at all ? There is a chance the touch is applying on your main monitor.
Try to re-install the TouchBase drivers. Also keep in mind that it requires a serial to be registered (should be included in some card , inside the box)
geposted Tue 05 Feb 19 @ 9:01 am
The touchscreen problem is solved , now i have no sound . All audiosettings are right , but when the touchscreen started working , the sound just stopped .
geposted Tue 05 Feb 19 @ 11:54 am
What is your current Audio aetup in VirtualDJ and where are your speakers connected to?
Check Task Manager and see if any additional VDJ instance is still running
geposted Tue 05 Feb 19 @ 5:58 pm
I already found it , was just a matter of updating Touch-drivers . Thanks for answering anyway .
geposted Tue 05 Feb 19 @ 10:06 pm
Again the Reloop Touch-screen isnt working . Or the soundcard works or the touchscreen , but never at the same time . I have already gone insane . hihihihihi
geposted Wed 06 Feb 19 @ 7:01 pm
I found the problem , there were too many usb-devices plugged into my PC . Never thought this could be a problem .
geposted Wed 06 Feb 19 @ 11:36 pm
How many devices were plugged in then? How were they plugged in? Shared between ports? Using a hub? Is the hub powered?
USB devices all use power, and USB ports can only supply a certain amount of power per port.
geposted Thu 07 Feb 19 @ 5:50 pm
I guess about 14 usb's were plugged in . Some of them in a powered hub , some of them in a normal hub , and some of them in the PC . I took out my xbox 360 controllers and suddenly the Reloop Touch worked fine . Anyway I'm glad that after 3 days of re-installing programs and drivers the problem is solved . By the way : the Reloop Touch was NOT connected to a hub , but to a single usb3 connection , so usb-ports draw power from each other .
geposted Thu 07 Feb 19 @ 6:37 pm
14 on one computer at one time? Sheesh, no wonder it all went pear shaped!
What on earth are all those things? You don't use 14 different devices while DJing do you?
geposted Thu 07 Feb 19 @ 6:50 pm
Its my daily-use computer .xbox one devise , xbox 360 devise , mouse , printer , 2 cellphones , keyboard , bluetooth-usb , phono-devise , usb-stick , cd-rom drive ,headphone usb-loader , camera , 2 hubs . I wish I had a laptop for my Reloop Touch , but I think I need 1500 euro's for a good MSI .
geposted Thu 07 Feb 19 @ 7:16 pm
