Hello, I would like to know if I can use FX Fade buttons, from the DDJ SB 3 controller, on virtual dj, by making a custom button. I own a different controller and I find these FX fade pads, very useful. What they do, is automate some tasks.
The ones who interest me are:
1) a pad that gradually enables high pass filter and goes to 100%, 3 bars after being pressed.
2) the same pad as above, but instead of high pass filter, use low pass filter.
3) a pad that creates a one beat loop, then echo out, and then fade the volume down.
When you press the pad(s) again, the effect will turn off.
Thanks in advance.
Thanks in advance.
geposted Sun 03 Mar 19 @ 6:10 pm
Did you ever figure out the custom 1 beat loop, echo out, and volume down? Im in search of the code for this as well.
geposted Sat 11 Apr 20 @ 12:31 am
