I googled for the answer and found out I need to use deck 1 unload. But this does not work. When i click on the pad nothing happens. I use VDj v8.3. Does anyone know what am I doing wrong here ?
geposted Wed 06 Mar 19 @ 7:11 am
I think when You use the Pads from this Deck you can write "unload" , without the Deck ;-)
geposted Wed 06 Mar 19 @ 8:08 am
Syntax ist ok, maybe you're on the wrong pad-page? Or the page was shifted?
What skin are you using? The default skin has unload by right clicking (and hold) on the stop button.
geposted Wed 06 Mar 19 @ 5:26 pm
I solved the problem partially. The syntax was wrong! It is not "deck 1 unload" but "unload deck 1". I say partially, because this allows me to remove a song only from the deck on which the script is called. So for example "unload deck 1 & unload deck 2" unloads first deck when called from the first and unloads the second deck when called from the second deck (but the first remains). My idea is to write a script that will clear all decks.
geposted Thu 07 Mar 19 @ 6:02 am
"unload deck 1" is definitely the wrong syntax. The "deck 1" part will be ignored, so it is exactly the same as writing "unload", which as you found out unloads the deck the script is called from.
"deck 1 unload & deck 2 unload" should work though. (depending also on loadSecurity option and if the decks are playing or not)
geposted Thu 07 Mar 19 @ 6:15 am
My current results are:
unload - no effect
deck 1 unload - no effect
unload deck 1 - removes song from the first deck (when called from the first deck)
unload deck default - removes song from the current deck
deck 1 unload & deck 2 unload - removes songs from both decks
This seems to be ridiculous that "deck 1 unload" does not work for me but "deck 1 unload & deck 2 unload" does. When I'll find a bit more time I will try to make screen recording so you guys could see the issue. Thanks for the responses.
unload - no effect
geposted Thu 07 Mar 19 @ 8:53 am
for me,
unload - unloaded deck it was on
These 2 unloaded the indicated deck when placed on either deck
deck 1 unload
deck 2 unload
deck 1 unload
deck 2 unload
geposted Thu 07 Mar 19 @ 9:03 am
It sometimes happens if a space or newline or something is added at the end.
Then the last "word" of the statement sometimes isn't parsed correctly
geposted Thu 07 Mar 19 @ 9:40 am
