With all options with internet in concern turned off, all online stuffs turn off and after the tip of the day was display, what can be this strange MODAL access showing "Downloading..." that appears after saying YES to the "You'll missed some features" box and makes VDJ wait for 30s/hang/crash when network is instable ?
It's specially sensible when a plugin make network access or if you click rapidely on some function before the message disapear.
when no internet access present there is no problem,.
As long as you do not answer the connection message there is no problem
Look the same as clicking rapidely on the next button in Tag Editor. Cover download related ?
geposted Thu 07 Mar 19 @ 5:57 am
No. It's the program checking for updates and if you just logged in, also validating your license.
geposted Thu 07 Mar 19 @ 8:13 am
Even when when checkUpdates is NO and does not have any account. strange.
The point is why does this stalls VDJ for some time stazrting with some miliseconds up to forever depending on network stability and loaded plugins?
geposted Thu 07 Mar 19 @ 1:52 pm
