Hello,
I currently have the "shader" feature engaged for audio only tracks, however I have a bunch of .avi, .asf, .mpg and .svp ambience background files that we used to use eons ago in VDJ 5.0 as visualizations. Can these be used still and if so, how do I point VDJ to them? Thanks for your help!
geposted Fri 08 Mar 19 @ 2:34 pm
You can use the Plugin "Slideshow".
Set it up in the Video Mixe Panel and the set the option "videoAudioOnlyVisualisation" to Slideshow aswell.
geposted Fri 08 Mar 19 @ 3:00 pm
Thanks! I knew it had to be easy, but couldn't figure it out!
geposted Fri 08 Mar 19 @ 4:11 pm
