Generally speaking "relocate missing file" has been working, however, I noticed that generally defaults to one drive - which requires a physical navigation through multiple drives to connect the file.
It appears to be ignoring my "E:" drive upon the initial search but allow physical navigation to the drive>path>file.
Any suggestions?
Any suggestions?
geposted Fri 29 Mar 19 @ 1:45 pm
If your are running VDJ on a PC, what you can do is throw all those missing files into a playlist, then fix the play list with 'Listfix' it works wonders plus is free, well at least is free so far. I fix all my moved playlist with this little software.
Link: http://listfix.sourceforge.net/
or
google it.
DjChachi
or
google it.
DjChachi
geposted Tue 02 Apr 19 @ 1:00 pm
