Just been looking at the list of supported controllers and I am unsure about something.
Some I can click on and see a manual and some I cannot click on.
Does this mean that, even though there is a picture of a controller, if you can't click on it, it is not supported or is there just no manual for it?
If it was once supported, then why would the manual not be available?
The reason i ask is that I have been offered a freebie Reloop Mixage, but the picture in the list is not clickable.
geposted Fri 29 Mar 19 @ 9:21 pm
No manual but supported with inbuilt mapper
geposted Fri 29 Mar 19 @ 9:25 pm
Ah, cool, can work without a manual.
Thanks for the heads up Kradcliffe.
geposted Fri 29 Mar 19 @ 9:28 pm
