Hello ! I got a Pioneer Sb3 controller for myself, I don’t work DJ, just a hobby. But my controller was originally made for the Serato program, but I didn’t like it. I like your program more, but I'm not sure that it will be able to unlock the capabilities of the controller. I wanted to know if you can make a trial version? And if so, how ?
geposted Tue 02 Apr 19 @ 9:07 am
Download the version ftom this site and it will work with your controller for 10 minutes at a time for you to evaluate.
geposted Tue 02 Apr 19 @ 9:10 am
Pioneer DDJ-SB3 works great with VirtualDJ.
And for trial, just download and install the software. Lets you try before you buy as mentioned above.
Setup guide:
https://virtualdj.com/manuals/hardware/pioneer/ddjsb3/setup.html
And after trial you need a license:
https://virtualdj.com/buy/ (Home or Pro)
geposted Tue 02 Apr 19 @ 10:28 am
