How do i set fader start no sync (or pitch zero)? Now it always Syncs
geposted Thu 04 Apr 19 @ 10:28 pm
If you mean the standard fader start (faderStart in the settings), that should only change the BPMs and/or Sync if you have one/some of the regular features for that enabled in VDJ
So try:
- disabling autoBpmMatch in the settings
- disable Smart Play on both decks
So try:
geposted Fri 05 Apr 19 @ 8:15 am
Disabling the Smart Play worked. Thanks a lot
geposted Fri 05 Apr 19 @ 6:34 pm
