Hello, I am very new to this and I would like to have this mix for today, so no time to watch how to videos.... yet.
If I have one workout mix that I like very much and would like to have it on a slower tempo, for example from 128 to 124, how can I do that on VDJ? How can I save it? I'm also using a Mac, so no right click available.
Thank you!
Thank you!
geposted Mon 08 Apr 19 @ 12:41 pm
You can either playback the file directly from VirtualDJ by using a tempo adjustment (like -3%) or playback and the file with a tempo adjustment and record the result on a new file.
PS: MAC's have right click as well. Hold down CMD button on your keyboard and tap your touchpad... Right-click magic!
geposted Mon 08 Apr 19 @ 1:20 pm
Hi, thank you for your answer. I just downloaded VDJ and adjusted the tempo by raising one of the bars, but the voice sounds awkward.
I am sorry if this looks.... bad... but how do I save it as playback - new file? What should I press for the voice to sound ok, what should I press to save it, without letting it play all? The workout mix is one hour long and when I tried to use the record function, it only saved the two minutes the song was playing.
This is my very first encounter with any DJ tool....
geposted Mon 08 Apr 19 @ 2:38 pm
I want to lower the tempo of the song, but the song should still sound all right and like the original song.
geposted Mon 08 Apr 19 @ 2:39 pm
Set master tempo on each deck
geposted Mon 08 Apr 19 @ 2:47 pm
