Updated Vdj this afternoon. Now I can't use needle drop. Clicking on wave form does not advance to that position. What the heck happened??
geposted Sun 28 Apr 19 @ 3:18 am
Default skin ?
geposted Sun 28 Apr 19 @ 5:45 am
PhantomDeejay wrote :
Default skin ?
Using vdj8 by fruit skin, not default.
geposted Sun 28 Apr 19 @ 9:36 am
Default skin ?
I just tested and it works for me with the FRUiT skin (Win7 32-bit VDJ Early Access b4909)
But I have seen other posts complaining that the FRUiT skin seems to have problems with handling recent builds
geposted Sun 28 Apr 19 @ 10:30 am
That's strange. Windows 10 64 bit here, and the FRUiT skin has the issue on both 32 and 64 bit versions of VDJ.
Hmmm......I just tried on my 32 bit Windows 8.1 laptop and it works OK.
geposted Sun 28 Apr 19 @ 10:49 am
I am using windows 10 64bit with a controller.
geposted Mon 29 Apr 19 @ 12:33 am
Ok. Until FRUiT comes up with a fix I would probably use another skin
geposted Mon 29 Apr 19 @ 12:37 am
kradcliffe wrote :
You could always try clearing the global variables line in settings.xml as it keeps all the skin specific settings and the fruit skin saves it's user settings there.
<VDJScriptGlobalVariables>
It's the option for cue position top/bottom that causes issue, clear the skin variables and don't pick either cue position for now
geposted Mon 29 Apr 19 @ 5:06 pm
