Simple problem here, but don't know what I did when I fiddled around in the Waveform area, I used to be able to left click ahead in the track and move it to that position. Or if I right clicked it, it took me to the POI Editor. But now when clicked on it, I get no action at all. I was messing around in the area clicking items on and off to see what was what and must have triggered something off, but cannot find it. Thank you in advance.
geposted Wed 01 May 19 @ 2:27 am
Are you using the default skin?
Because I think older un-updated skins like the FRUiT skin have this problem with recent VDJ versions
geposted Wed 01 May 19 @ 5:36 am
For the skin The Thing: Opt button [top right] >waveform markers off
For Fruit's Skin: vdj logo under the crossfader>positions>cues turn which every you have selected on to off [top/bottom]
DjDad has said they're fixing it for the next build, then you can go back to using these options.
geposted Wed 01 May 19 @ 11:57 am
LocoDog - Thank you very much! Okay, so under the Crossfader, went to "positions", then to "cues" and noticed I had "top" selected, so I shut it off...so that was the culprit! Thanks again.
geposted Wed 01 May 19 @ 5:08 pm
Dear Klaus,
Thank you very much for replying to help out. Yes, I am using FRUIT's skin. LogoDog has figured out the exact solution for me. :)
geposted Wed 01 May 19 @ 5:09 pm
It was actually dj lylian found the cause.
geposted Wed 01 May 19 @ 5:17 pm
Logodog...Oh okay, then thanks to DJ Lylian as well... Peace and Love!!
geposted Wed 01 May 19 @ 6:25 pm
