After the last update, Eq 10 is gone and i cannot reinstall it from extensions. There is another called EQ 10 which is not the same. Eq 10 counts on % and EQ 10 on db. i have described eq % on many of my tracks so the db description is not usefull.
geposted Sun 05 May 19 @ 4:56 pm
You could rename the original dll to something like 'EQ10 Original.dll" in your Documents\VirtualDJ\Plugins folder if you still want to use the earlier one.
geposted Sun 05 May 19 @ 5:30 pm
I have the following description in my Documents/Plugins : "EQ10 Original.dll.ini" but it doesnt work. I have also removed . ini but it still doesnt work.
geposted Sun 05 May 19 @ 5:50 pm
I have written the line in Sound Effects and it works. Thanks a lot
geposted Sun 05 May 19 @ 6:00 pm
