I'm sure this has been posted somewhere before, and if so, I'm sorry. I've searched for it, but apparently don't know the proper search criteria.
IS there a way to change the previously played songs to a different color, similar to Serato? for example... Standard song list shows all songs in white w/ black background. Once they're played, can the entire line of the song be changed to say, Sky Blue or something?
Thank you!
Thank you!
geposted Wed 29 May 19 @ 12:30 am
I don't think so - at least not in the default skin - the reason being that color coding is used for other purposes
So in VDJ it's shown on the track icon
geposted Wed 29 May 19 @ 12:40 pm
This has been a regularly requested feature, but Atomix have not implemented it.
I'm sure it was thought about, it would be possible to do without causing a problem with the existing manual colour selection.
For example, once a colour is chosen by the user to represent played tracks, that colour is then no longer available for other purposes (because it's already been assigned).
Maybe even have an option to change the font for played tracks too, making them stand out even more.
Of course there would need to be a choice of time period that VDJ waited before resetting the track to unplayed status again.
geposted Wed 29 May 19 @ 4:20 pm
Ok, Thank you guys! I think there needs to be something other than a small square dot on the icon. I mean, if you're in a hurry scrolling through, it's tough to see... I do a lot of outside work (outside on a deck in sunlight) and it's really tough. Heck, Maybe a good suggestion would be to just have the icon disappear if the track has been played! ??
geposted Mon 03 Jun 19 @ 12:30 am
