A new pad page that needs testing, It automagically moves sliders, on beat , to a beat duration, across 2 values that you set.
If you want in post here.
geposted Mon 03 Jun 19 @ 11:41 am
i could be tempted
geposted Mon 03 Jun 19 @ 7:09 pm
looks promizing for use with lights control
geposted Mon 03 Jun 19 @ 10:57 pm
Is the one you set me?? If so I had a little 5 minute go and it looks very promising!!
geposted Tue 04 Jun 19 @ 3:42 am
The fx slider one sent today, [not video the other day] yup.
I think it has promise, I'd risk saying everybody would have at least one use for it.
Try shader as a deck fx to see some truly mental [change shader every 32ms XD ]
I've been hammering cut [dial 2], loopRoll and filters.
Little tip calling dial 2 on fx that don't have dial 2 and you just have timed fx on/off
There's a tiny timing niggle to fix [like 32ms tiny], I need to give the script some sort of check over as I'm sure there's parts that are never used.
Then there's making it work on several decks at once [no big thing, copy paste]
Then there's ideas from testers.
geposted Tue 04 Jun 19 @ 5:22 am
@Nicotux, post your pro account so I can send you his trial.
geposted Tue 04 Jun 19 @ 5:55 am
I'd like a trial too please
geposted Tue 04 Jun 19 @ 6:06 am
Inbound..
geposted Tue 04 Jun 19 @ 6:08 am
A few questions from me, what fx are you liking with this?
Anything you like a lot, make a note of it, [fx name, slider, max, min, beat duration] because it could be made into a zero set up button [no dials or beat setting to enter, just a single press]
geposted Wed 05 Jun 19 @ 12:57 am
I found a bug, with snap off if you have a "sequence" running, than change the beat param and queue another "sequence" (for the same slot) the params aren't updated. [it runs with the last set of params]
Shouldn't be too hard to fix.
Added color fx [padshifts 4 & 8] [these reset to centre]
Added some LED logic, if sequence is running pad is lit, if a sequence is queued pad flashes
Added some pretty button names [no longer the mess of variables I used for testing]
Not sure on pad colours
geposted Wed 05 Jun 19 @ 6:07 am
ok
geposted Wed 05 Jun 19 @ 6:10 am
PM sent
geposted Wed 05 Jun 19 @ 6:15 am
