Hello fellow DJ's,
I just upgraded to a Turbosound 2000 v2. I used to run with unpowered speakers and powered mixer to DJ Karaoke and special events and weddings. I understand a little about sound and still learning. I can hear it, but totally still working on how to adjust it the way I need it done to sound perfect. I am NOT a sound guy/girl. I need help setting this speaker eq. Does anyone have this speaker and can you help? I run a Mackie 8 channel mixer with this speaker, so all my eq is coming from my mixer.
Thank you in advance.
Angela
Angela
geposted Wed 05 Jun 19 @ 1:10 am
You mean the iNSPIRE iP2000?
What's wrong with the sound that makes you think it needs EQ? With good quality source material, mixer and speakers, it should sound fine without needing any EQ at all.
geposted Wed 05 Jun 19 @ 6:21 pm
I run twin IP2000s. I don't use any eq, with the exception of the internal settings on the IP itself, and that usually only involves bumping up the bass. Feed them good quality files, and these things sound awesome. Question..have you tried running them straight off the computer? That may give you a clue to whether your mixer might be causing the issue.
geposted Fri 07 Jun 19 @ 11:40 am
Yes inspire 2000. The EQ in the speaker is flat lined but then I have the base -1 and so on. Should these levels be 0 out.
geposted Sat 08 Jun 19 @ 7:35 pm
