I followed instructions and ... Add Filter Folder (far left pane) , Named the Folder Karaoke, Then typed as instructed Type="karaoke" , next was select Database, I selected the catagories like Artist, Title Comment, length .
Here is question: After doing this, i closed the window and it worked great BUT i must have missed a step (brain dead) I did not see an Enter , Select, Apply, OK (after filling in the Filter info) I simply X'd out of the window. When I played a normal music song, I then went back to the filter folder, expecting to see only karaoke songs but there was nothing. I clicked on my recently created Karaoke Filter Folder and typed a song in the search window.... Everything popped up, Music, Karaoke etc. Where have i missed a step.
Is there anything I need to do by Right clicking on the New Blue Karaoke Filter folder and choosing Batch reload tags, Add to Search DB?
I was hoping to use as I have for years, as I do karaoke shows it only searches karaoke songs
Thank you in advance.
geposted Wed 05 Jun 19 @ 8:23 pm
I suggest you read the VDJ 8 manual, Michael. The browser has buttons for showing music, video or karaoke files.
geposted Wed 05 Jun 19 @ 8:35 pm
believe me ... I understand, I have selected show karaoke, show music and show video. you have been very helpful. Where is the manual and I'll give it a read to keep from taking time for more serious questions. I just thought I would ask , hoping it was simple ... don't want to be a leach
I wasn't aware that it had a built in filter for music , Video and Karaoke... it's the little tiny dark gray, on black button or the far left panel, about an inch from the bottom... I didn't know I had to select each one.... I DO NOW ! thanks
Hope my silly questions help some other poor soul. Many thanks again for your patience and understanding.
geposted Wed 05 Jun 19 @ 9:00 pm
The manual is unfortunately not included in the VDJ download any more. It's online only, which I think is ridiculous for DJ software (likely to be used away from network connections).
You can find it via the Support menu at the top of this site.
geposted Wed 05 Jun 19 @ 9:44 pm
