Files are tagged properly. Looking for a way to choose multiple titles and add something to the end of the title.
geposted Wed 19 Jun 19 @ 2:00 pm
Append tags, not sure if vdj can do that on its own, i know you can with the builder addon (Windows) in fact i think i posted the script for builder, I'll check.
geposted Wed 19 Jun 19 @ 2:18 pm
Thanks looking forward to try.
geposted Thu 20 Jun 19 @ 12:56 pm
I've found the script, I'll adapt it later this evening.
geposted Thu 20 Jun 19 @ 2:06 pm
Sorry forgot about this;
Here's the basics, enough I think for you to get started, if you can't get it to work post back and we'll figure it out.
locodog wrote :
A user wanted to append tags, I don't think this isn't possible with straight script but you can with builder :-)
This example takes fields 1 & 2 adds a comma inbetween them and then writes to field 1 and clears field 2
I used a custom button to set fields 1 & 2
browsed_song 'Field1' 'erm' & browsed_song 'Field2' 'yes'
I then used another custom to get builder to read/parse field1 insert a comma and read/parse field 2, then I added a bit more script to read builders string and cast it to field 1 & also cleared field2
get_text "`get_browsed_song 'Field1'`,`get_browsed_song 'Field2'`" & param_cast "text" & effect_string 'builder' 1 & get_effect_string 'builder' 1 & browsed_song 'Field1' & browsed_song "Field2" ""
geposted Mon 01 Jul 19 @ 1:10 am
using the same button
this one can be done without the need of builder :
get_text "`get_browsed_song 'Field1'`,`get_browsed_song 'Field2'`" & param_cast "text" & browsed_song 'Field1' & browsed_song "Field2" ""
because it is only used as a string variable in this case
geposted Mon 01 Jul 19 @ 4:23 am
So it does, I never tried this simpler application
get_text "`get_browsed_song 'title'` YOURTEXT" & param_cast "text" & browsed_song 'title'
geposted Mon 01 Jul 19 @ 4:47 am
Thanks, unfortunately cannot get it to work.
What I am trying to do is.
Choose multiple song titles, within VDJ add a comment
at the end of the song title.
Example: song title [word]
I think you would need a filter folder with a certain script.
Then choose multiple songs and add the filter.
Would this be the correct way?
geposted Mon 01 Jul 19 @ 6:58 pm
If i understand you want to alter a set of tracks by adding some common [word] to every title
What i would do is first to create a playlist with these files
if you wanna add the same [word] to all the titles previous scripts will work
Here is a proposal i would try:
- use the "Text" plugin as a text input box not to have to alter the script every time
- script to add the [word] to the title only if not already present
- iterate all the playlist
I call this button " Append `get_effect_string text 2`"
The script:
effect_show_gui text & repeat_start 'rept' 300ms -1 & effect_show_gui text ? nothing : repeat_stop rept & get_effect_string text 2 '' ? nothing : sideview sidelist & browser_window sideview & browser_move top & repeat_start_instant 'rept' 30ms -1 & get_browsed_song title & param_cast text & param_contains "`get_effect_string text 2`" ? browser_scroll +1 : get_text "`get_browsed_song 'title'``get_effect_string text 2`" & param_cast text & browsed_song title & set pos "`get_browsed_selection_index 99999`" & browser_scroll +1 & param_equal "`get_var pos`" "`get_browsed_selection_index 99999`" ? repeat_stop rept : nothing
Usage:
Create a playlist with the files to be alteres
click the button
enter text
close the gui
wait the browser to reach bottom
you are done
may enhance the script by testing text is not empty to abort
The script:
Usage:
click the button
enter text
close the gui
you are done
geposted Tue 02 Jul 19 @ 1:24 am
if its simply to add a comment...
alter the comment field
If you wanna alter the filename you need select all the files in the playlist and tag edit the block and rename as "Artist - Title (Comment)"
all files will become "Artist - Title [word] (Comment).ext"
and then batch reload tags
take care of adding initial space and bracket in the text input box
geposted Tue 02 Jul 19 @ 1:37 am
..? nothing
..: repeat_stop rept &
....get_effect_string text 2 ''
....? nothing
....: sideview sidelist &
......browser_window sideview &
......browser_move top &
......repeat_start_instant 'rept' 30ms -1 &
......get_browsed_song title &
......param_cast text &
......param_contains "`get_effect_string text 2`"
......? browser_scroll +1
......: get_text "`get_browsed_song 'title'``get_effect_string text 2`" &
........param_cast text &
........browsed_song title &
........set pos "`get_browsed_selection_index 99999`" &
........browser_scroll +1 &
........param_equal "`get_var pos`" "`get_browsed_selection_index 99999`"
........? repeat_stop rept
........: nothing
geposted Tue 02 Jul 19 @ 2:16 am
