@ groovindj
Tag & rename for your tags, and a wee program called Creevity a bit slow and time consuming but does the job
geposted Tue 09 Jun 20 @ 6:48 pm
@ kradcliffe
Again, I went from MCX8000 to the Prime 4 almost a week ago, Engine Prime has been superb, Now we have VDJ supported we have the best of both worlds.
Save buying Resolume @ £££ and having to convert mp4's across to another file system that it supports.
So far it has been great......Well done VDJ & Denon
geposted Tue 09 Jun 20 @ 6:53 pm
So I guess the Prime 4 plays video files as audio only in standalone mode?
My only real gripe is having to reboot to change mode. Engine Prime seems to have got a bit better (need to try the latest release). I see the BPM scan algorithm is still not good on the Prime 4 itself but this will be updated in time I guess. People have been waiting forever for track preview though so it could be long enough.
geposted Tue 09 Jun 20 @ 7:49 pm
The rebooting seems fairly quick to me. I don't know if you could perhaps play audio through the mixer while it's doing that. Haven't tried.
geposted Tue 09 Jun 20 @ 7:54 pm
hey all - I installed the skin, but it is not showing anywhere. Thoughts? Also, is the P4 in computer mode?
geposted Wed 10 Jun 20 @ 1:34 am
P4 has to be in computer mode, yes. The skin won't show in the VDJ skin list (if that's what you mean) as it's hidden because it's for the Denon screen.
Did VDJ detect the P4 and pop up a sound config window?
The P4 skin zip has to be in the skins directory, the P4 mapping zip file has to be in the devices folder.
There are also two files that go in the Plugins64 folder (assuming Windows 10), which are supposed to download automatically when VDJ detects the P4. Maybe they didn't download (mine didn't). Check the folder for AKAIREMOTESCREEN64.dll and libusb-1.0.dll files.
geposted Wed 10 Jun 20 @ 6:29 am
Just tested it 1 hour yesterday and just love it.
All i wanted was a 4 channel with mic support and software what can be used as Karaoke equipment ... and that it is <3
Prime 4 + Virtual DJ = Epic Love
Here is some " fix it would be awesome " ... form-wave is a bit laggy it could be of my computer ( gonna check it out later ), the FX from the Controller is still a bit nah not okay and the jog wheels art is missing ... but as i said before " fix it would be awesome " :)
geposted Wed 10 Jun 20 @ 9:01 am
The slow waveforms were mentioned by djdad in an earlier post. It's a problem with the refresh speed of the screen (when used over USB presumably).
For the jogwheel art, check in the skin settings (hold the 'view' key down) and you'll probably find that the brightness for the jog display is at zero.
geposted Wed 10 Jun 20 @ 9:15 am
Jogwheels now work with new mapping update, but the screen not after the update :/
geposted Wed 10 Jun 20 @ 9:19 am
Thanks for the info <3
geposted Wed 10 Jun 20 @ 10:27 am
Good to know - A window did not pop up but it did show in the audio settings. I will check the directory and folders. Ive had the prime for over a year - I have no intentions on using VDJ with the P4, but I am curious to see how it works. Curious tho, I just got the Prime GO will this work with that too, or different coding?
geposted Wed 10 Jun 20 @ 5:54 pm
@djdad i tried to make all but i dont become all to work.
The new mapping update works with the jogwheels. Then dont work the main screen.
When i use the old mapping before the 10.06.2020 it works..
you can solve the problem?
geposted Wed 10 Jun 20 @ 6:05 pm
Denon says the Prime GO will not be compatible with the SDK, no plans either, so no, screen wont work and not sure if the device will even work as MIDI controller.
So if your plan was to use it with VirtualDJ (or any other DJ software) better return and buy something else.
geposted Wed 10 Jun 20 @ 6:34 pm
Same here, main screen not working with installed mapper update.
geposted Wed 10 Jun 20 @ 6:48 pm
the jogwheels screens are working now but It seems there's a problem, You can't see loop size numbers anymore when you change it (maybe it's because of the album cover?)
geposted Wed 10 Jun 20 @ 6:56 pm
DJDAD. when i use the asio drives everything works fine but you cant use the broadcast button as the volume is very low. When you use the wasup drives you can broadcast and levels are good but the cue buttons dont work hence cant hear mix. Which drives are better to use in your opinion i tried what you said in earlier post that does not work.
geposted Wed 10 Jun 20 @ 10:18 pm
I just did a quick little experiment here...
Connect an "emergency playback device" (Sony NW-E99) to a line input of the Prime 4 and play some music through it. While it's doing that, switch from standalone to computer mode. Playback continues without issue.
When VDJ got to the point of seeing the Prime 4, there was the tiniest dropout (split second) in the music from the line input. I was then able to load a VDJ track to a P4 deck, press play and fade out the line input signal.
I'd say that's workable. :-)
geposted Thu 11 Jun 20 @ 11:17 am
Thanks for the idea. It really works. It's a good solution for safe.
geposted Thu 11 Jun 20 @ 12:53 pm
Yes, it also works the other way (VDJ to internal) and you can still talk on the mic as well.
As it's always wise to have some kind of backup music source anyway, routing it through the line input while switching modes (should you ever need to) is a simple solution.
geposted Thu 11 Jun 20 @ 1:03 pm
nobody an idea, because the new Update? The screen dont work ?
geposted Thu 11 Jun 20 @ 1:09 pm
