stupid question - How do you change video settings I use to be able to adjust video size by dragging corner to whatever size, now it is either maximized or just minimized.
Went into interface and have messed with the forced maximize and other things or is it the skin?
Thanks in advance!
Thanks in advance!
geposted Fri 28 Jun 19 @ 6:54 pm
Double-click inside the video window to have it windowed, then you can resize and move at will. Double-click to maximize again
geposted Sat 29 Jun 19 @ 4:35 am
