Hi Atomix!
I've included VirtualDJ 2018 in my Key Analysis Accuracy Comparison 2019 (12 apps compared with 840 tracks) too!
Check it out here: https://www.reddit.com/r/DJs/comments/cewbal/key_analysis_accuracy_comparison_2019/
geposted Sun 21 Jul 19 @ 11:35 pm
Which detection algorithm did you use in vdj?
geposted Mon 22 Jul 19 @ 1:15 am
Default.
geposted Mon 22 Jul 19 @ 8:36 am
Is there any advice available what preferences should be changed after a fresh installation?
Is there a reason why this isn't set by default?
geposted Mon 22 Jul 19 @ 9:08 am
I honestly can't remember if broad range or electronic is the default, I'd guess it's electronic.
The most common set ups is how the options are for default, but given the range of hardware and options available it's sort of up to you to tweak to your preferences, because they're your preferences. I don't know what you like.
geposted Mon 22 Jul 19 @ 9:27 am
Thanks.
I like accuracy on electronic dance music key dectection wise =)
geposted Mon 22 Jul 19 @ 10:28 am
Oops...
Factory default = Broad range.
See: https://gyazo.com/9cba8c14ccf4d81609beabe90ebaf860
That's what I tested it with.
Since the tracks used are mostly electronic I should re-do the test on that other algorithm.
Thanks for pointing this out!
geposted Mon 22 Jul 19 @ 10:35 am
That's why I asked, I'm totally up for empirical testing but it's got to be apples to apples.
geposted Mon 22 Jul 19 @ 10:37 am
No, you should be using broad range.
'Electronic' is there only for having the same keys as in VDJ 7, but unless you only have music in minor key it's not really useful.
geposted Mon 22 Jul 19 @ 11:11 am
I've thought about using mixedinkey before, but I don't seem to have a problem finding songs that are harmonically compatible with VDJ8. Even if a 5A isn't really a 5A, I can still find what sounds great together. I've heard musicians hear keys differently and they won't agree with each other 100% of the time. I've found a lot of songs with the same harmonic key which sounds awful together. Good blends happen when 2 tracks compliment each other. If both tracks are too busy, it won't matter what the software says about them.
I remember having this discussion with the Guitar Center and he admitted it's not going to get you amazing blends every time. The software key analysis isn't something to rely on since keys change throughout the sections/phrases of a track, like the intro and outro verses in the body of the track. Also, some tracks have clapapella or acapella intros and outros or something else. Software analyzes the meat of a track, but not the short intros and outros, but I've heard mixedinkey use to give the key per section of a track, but not anymore? I use it as a guide, but it's good to double-check different options with our own ears.
DJs aren't lazy people by any means. DJs have been mixing for decades and making killer mixes even without software. Peace out and have a good session!
geposted Fri 26 Jul 19 @ 6:49 am
