I'm manly playing Techno, and Tech House, and want to layer my Tracks more. I want to take some parts of a Song on a different deck to repeatedly play them while continuing with mixing other song.
So my Question is, is it possible, to have a dedicated deck (e. g. deck 3 & 4) as a "loop Deck".
What i mean by this, i want to play normally 2 songs on the first 2 Decks.
Then I make a loop on the 1. deck of a (Vocal) passage, and after that i want a dedicated button that sends that loop, or the whole song with this loop running, on a 3rd Deck.
So i can end the loop on the 1. Deck and let the song play out and mix it with the song on the second deck. But now I'm able to repeatedly play that looping part of that Song on the 3rd deck and reintroduce it again and again, while being able to play effects and use EQ etc. Similiar to what Carl Cox is describing here with the looper. https://www.youtube.com/watch?v=NwBrd9a1LdA
I hope you understand me. Maybe I'm just talking about normal Sampler Functions, but I only got the Numark Mixtrack Platinum Controller and i am trying to fit that usecase with that gear :D
Thanks
Thanks
geposted Tue 30 Jul 19 @ 12:44 am
This is what clone_deck does : i.e. " deck 3 clone_deck 1" or "deck 4 clone deck Left"
loops are transfered as well as the track and decks are initially sync but still independant
assuming you use default skin 4 or 6 decks layout: same as scratch panel "clone" functions between right and left deck
have to assign temporary deck 3 or 4 to right prior to clone left and so on
geposted Tue 30 Jul 19 @ 1:30 am
cloneLoop padpage does exactly that I'll ask djdad to lift the licence restriction
geposted Tue 30 Jul 19 @ 2:36 am
