Hi, I'm using the free version of virtual dj.
Is there a way to change the key gradually rather than using the drop down? (I'm looking to get a smooth transition from one key to another, or to reset the key back to 0).
A knob/slider would be great for this, but if I need to bind it to the keyboard that's fine too as long as it's easy to view on screen. From what I can see online a key knob used to exist but does not anymore for some strange reason.
Thank you for taking the time to answer!
geposted Thu 01 Aug 19 @ 1:44 am
