How to install a previous build? Do I need to uninstall b.5182. Need step by step instructions please.
geposted Wed 07 Aug 19 @ 1:03 pm
1. Download the old build from here: http://www.virtualdj.com/download/build.html
2. Simply install on top
3. If that doesn't work (if for some reason the .exe file is locked/doesn't get overwritten), rename the virtualdj.exe file first - like put the build no in the file name
4. Simply install on top again - pick "repair" if that is suggested by the installer
5. The benefit of no 3 is that you can have both versions installed at the same time
geposted Wed 07 Aug 19 @ 1:47 pm
Thank you:)
geposted Wed 07 Aug 19 @ 3:05 pm
I'm trying to get build 5504 and i'm only able to go up to 5630 when i click on the link and nothing earlier. How can i get 5504?
geposted Wed 20 Jan 21 @ 1:05 am
Why do you want 5504? What's wrong with all the other builds?
geposted Wed 20 Jan 21 @ 8:46 am
