Hello DJs,
How can I change the latency number in VDJ?
mine is set on 1120 and when I change the number, it reverts to 1120.
Please advise.
I'm using VDJ8, Windows 7, NS6II.
Please advise.
geposted Tue 20 Aug 19 @ 6:49 pm
When a controller has its own dedicated audio driver, you would normally adjust latency from there, not from VDJ.
geposted Tue 20 Aug 19 @ 7:32 pm
thank you.
it can be done in traktor so I thought latency could be changed in vdj too.
geposted Wed 21 Aug 19 @ 2:56 pm
I didn't say it can't be changed in VDJ. It can, but the driver is the place to do it when you have a dedicated low latency audio interface (and VDJ should follow that setting).
geposted Wed 21 Aug 19 @ 4:26 pm
Open settings and go on Sound Setup tab.
Click the "ASIO" button
Adjust latency there (on the driver) and close the driver window.
Hit apply on VirtualDJ settings window
Close settings
Done!
Close settings
Done!
geposted Thu 22 Aug 19 @ 7:56 am
