Pls after scratching, it sometimes start normal and sometimes too dismix it doesn't march like how I like it so there is a way that after releasing it starts from hot_cue
geposted Wed 21 Aug 19 @ 1:11 pm
There is a way so that it starts where it would have been if you haven't started scratching
It's called "slip mode", and depending on your controller, there is probably a button for it - if not you can select it on the deck on the screen
But also remember: You usually don't scratch on the playing deck
You usually scratch a specific sound on the opposite deck, and then "cut it in" using the crossfader - and then back out when there is no more scratching
That way the playing track/deck isn't touched/disturbed at all, and simply continue playing
geposted Wed 21 Aug 19 @ 2:04 pm
Thanks for that but I mean immediately u remove your hand from the jog wheel then it starts from the hot cue u used
geposted Wed 21 Aug 19 @ 2:32 pm
Pls Djs, nothing like that or?
geposted Thu 22 Aug 19 @ 10:35 am
How do you scratch ? Mouse ? Controller ? DVS ?
geposted Thu 22 Aug 19 @ 11:28 am
Please, I use controller and I use numark mixtrack platinum. I sometimes too uses keyboard
geposted Thu 22 Aug 19 @ 5:21 pm
Put this command on a button:
repeat_start_instant 'ScrRelFX' ? repeat_stop 'ScrRelFX' : repeat_start_instant 'ScrRelFX' 5ms & touchwheel_touch ? set 'VinylTouch' 1 : var_equal 'VinylTouch' 1 ? set 'VinylTouch' 0 & goto_cue : nothing
Click on the button to engage auto return. Click again to turn off.
This command is per deck, therefore you want to map a button that's common on both sides of your controller.
Edit: for the LED of the button use
repeat_start_instant 'ScrRelFX' ? on : off
OR:
repeat_start_instant 'ScrRelFX' ? var_equal 'VinylTouch' 1 ? blink 250ms : on : off
OR:
geposted Thu 22 Aug 19 @ 9:15 pm
Thanks Boss
geposted Thu 22 Aug 19 @ 10:27 pm
Boss u do all and my last question.
Please do we have a way that, maybe when playing the song and u want to start from SKIP SILENCE not cue point.
Because if I cue from that point it won't march the song.
geposted Thu 22 Aug 19 @ 10:35 pm
Boss please where to put this one is the problem but the first one works and i think if i add it, it will make it work better.
please am talking about this
OR:
OR:
geposted Thu 22 Aug 19 @ 11:49 pm
Please Boss am still waiting
geposted Fri 23 Aug 19 @ 8:52 pm
it goes on the led mapping
geposted Fri 23 Aug 19 @ 9:02 pm
I mean the type, we have led jog, etc so boss please which one
geposted Fri 23 Aug 19 @ 11:23 pm
On the led of the button you used to put the code above
If you used the button FX3 for instance then you need to enter the code on the LED_FX3
geposted Fri 23 Aug 19 @ 11:49 pm
OK Boss. Thanks very much u do all.
My scratch DNA doesn't scratch it always play as hot cue.
Please help me to fix it up.
geposted Sat 24 Aug 19 @ 9:03 am
No answer
geposted Mon 26 Aug 19 @ 11:15 am
