So I was playing with the Automix function on 2018 and when it loads a song it cues deep into the song and the outro is way early. Due I have to go into the editor and move the points on each song or is there a "smart" function?
I don't want to go through 90 thousand songs and set ins and out on every single one. :(
geposted Sun 25 Aug 19 @ 4:47 pm
If you go to settings , then options , then type in 'automix' , then you see 'automixMode' , there you can change settings . I think thats the option you need .
geposted Sun 25 Aug 19 @ 9:39 pm
