Can this be implemented please....
geposted Tue 27 Aug 19 @ 4:16 am
I thought there were some settings implemented that handled that. Can't check at work sorry
geposted Tue 27 Aug 19 @ 12:46 pm
setting "readOnly"
geposted Tue 27 Aug 19 @ 1:01 pm
In windows or VDJ... I don't want global read-only. Just in VDJ.
geposted Wed 28 Aug 19 @ 2:32 am
Also I don't want it locked until I'm happy with the analysis. So individual locking is what I look for. Plus if I will that automatically lock tracks so I can't repair the wrong cbg placement.
geposted Wed 28 Aug 19 @ 2:35 am
Keep a backup then...
geposted Wed 28 Aug 19 @ 4:01 am
All that, why can't I just click a lock icon in the browser. That way I can tapout different timing for echoes and other effects, on the fly, without changing the original analysis. Doesn't that make better sense? I do a lot of things by tapping but then have to reset the cbg because it double or halves. I do tapping because of earlier mixers where you tapped in the echo timing...
geposted Wed 28 Aug 19 @ 11:47 am
But if the analysis is correct, why do you still tap?
geposted Wed 28 Aug 19 @ 12:42 pm
He taps out different timings....
I do the same thing sometimes. For example, if the track is 120bpm but you want to put an effect on it, synced to 60bpm.
geposted Wed 28 Aug 19 @ 2:14 pm
For such cases I have 2 buttons to either half or double the bpm, quicker to action and doesn't alter your first beat.
Tap for fx is a bit of a bodge if you can instead, do it mathematically. Even for out of sync use.
geposted Wed 28 Aug 19 @ 2:25 pm
I'll try this...just used to tapping on the fly...
geposted Fri 30 Aug 19 @ 2:11 pm
