Topic: Virtual Dj Clonar Deck Pioneer Ddj
How can I configure the option to clonar deck in virtual 8 with my pioneer ddj sx controllers ?
geposted Wed 28 Aug 19 @ 4:02 pm
Assign a button to clone_deck
I think you should be more specific, because I have not found a way to assign it, otherwise I would not ask.
Best choice imo would be to add this functionality to the LOAD buttons, but sacrificing the unload function when long held.
The procedure to map a controller button is described here.. https://virtualdj.com/manuals/virtualdj/settings/controllers.html#custom%20mapping
For the Action for the LOAD button you will need to replace the action ...
holding ? unload : load
with ...
doubleclick ? clone_from_deck : load
Then you can double-fast press the LOAD button to clone from the other deck or just press to load.
Thank you very much for your response, it will help me a lot.
Greeting Dj Dad
