Hi,
I am loading an audio track (.ogg format) and trying to extract a sample from that. I select a loop and the record. It does the job. What is NOT working is that if I add any effect (alter key, bpm, put some flanger, reverb etc...) while I can hear the effects correctly, the sample is recorded without any of those effects.
Where am I wrong?
Thanks!
Where am I wrong?
Thanks!
geposted Mon 02 Sep 19 @ 9:44 am
recording a sample while in a loop doesn't record real time audio it just extracts what is between the loop in & out from the track as data, instantly,
to record real time you need to record out of a loop
I think I figured out single press RTaudio recording for a set beat duration a while back.
geposted Mon 02 Sep 19 @ 10:02 am
