Liebe VirtualDJ Gemeinde,
heute haben wir ein neues Release veröffentlicht, welches wie immer kostenfrei ist.
Diejenigen welche die automatischen Updates eingeschaltet haben, bekommen das Update sofort.
Alle anderen bitte entweder unter Optionen aktivieren oder eben neu laden.
http://www.virtualdj.com/download/index.html
Stephane Clavel wrote :
VirtualDJ 2020 just got released today.
In addition to some new features like the Event Scheduler, Beatport streaming, a better harmonic mixing with auto pitching, etc, it also brings a brand new modern look adapted to all kind of DJs.
It is completely safe to upgrade from VirtualDJ 2018 to VirtualDJ 2020.
All your settings and database will stay the same.
Only the design of the interface will change, and if you want to keep using the old one for a little bit longer, you can still find it in Settings->Interface->Old
Another change with VirtualDJ 2020, is that the PC version is now 64bit by default. (mac has always been 64bit-only since VirtualDJ 8.0)
If your VirtualDJ is auto-updating from VirtualDJ 2018, you will be on the 32bit version.
If you want to switch to the 64bit version, you need to download and run the installer manually.
(the difference between 32bit and 64bit version, is that the 64bit version is a bit faster, and use the latest video optimizations of your videocard. But some third-party plugins that have been written only for 32bit will work only with the 32bit version)
Also, like usual, the update to VirtualDJ 2020 is completely FREE.
Enjoy !
Enjoy !
Viel Spaß
geposted Sun 22 Sep 19 @ 12:01 pm
Wow vielen Dank ans Gesammte Team und alle die dran mitgewirkt haben,werde das demnächst dann Mal antesten /installieren müssen,wenn ich mehr Zeit habe.
Klasse auch das es eine 32+64 Bit Version gibt.
Großes Dankeschön.
Mfg,Dirk
Großes Dankeschön.
Mfg,Dirk
geposted Sun 22 Sep 19 @ 12:22 pm
Hallo,
auch von mir ein großes Danke an das Team.
Ich finde das Design gelungen, einzig an das VU Meter muss ich mich gewöhnen.
Aber ansonsten ein sehr schönes Design.
VG
Frank
VG
Frank
geposted Sun 22 Sep 19 @ 1:19 pm
da freue mich mich doch darauf - aber... was ist denn nun neu ??? Und gibt es endlich neue Skins zur Auswahl - nicht mehr so die megabunten.... ;-) LG
geposted Sun 22 Sep 19 @ 3:02 pm
Ha, ich war etwas erschrocken. Starte mein Vdj und es sieht ganz anders aus. Ob's mir gefällt kann ich noch nicht sagen. Bin noch am testen.
Auch ich sage schon mal danke. Habe erst am 2. Oktober wieder VA, also genug Zeit zum testen.
geposted Sun 22 Sep 19 @ 3:40 pm
geposted Sun 22 Sep 19 @ 5:32 pm
Ich warte lieber, ob es vielleicht ungewollte featurs gibt.
Kann dann immer noch das Update machen.
geposted Sun 22 Sep 19 @ 6:09 pm
Ich habe es installiert und ich liebe es! Die waveform ist endlich so wie ich sie haben wollte. Und die Steuerung ist sehr smoothly! Echt cool.
Cool ist ja auch der ereignisplaner! Das man eine Uhrzeit und eine Datei auswählt, und dann wird sie abgespielt. Das abspielen hat noch nicht geklappt, warum weiss ich nicht, da muss ich noch mal gucken, aber das ust schon Mega.
Danke an das vdj team
geposted Sun 22 Sep 19 @ 6:44 pm
habe es getestet,absolut top
geposted Sun 22 Sep 19 @ 6:45 pm
An alle die "Angst" vor dem neuen Skin haben:
Den alten gibt´s immer noch unter Skins in den Optionen.
Auch das Zurücksetzen auf die Vorgängerversion geht mit diesem Link:
http://www.virtualdj.com/download/build.html
wird aber in beiden Fällen nicht nötig sein ;-)
geposted Sun 22 Sep 19 @ 7:00 pm
Uiiiiii, da gibt es ja einen recht neuen, ungewohnten Anblick. :-)
Erstmal toll, dass Atomix immer am Ball ist um VDJ noch ein bisschen besser zu machen, aber da bleibt eine Menge zum testen und einstellen.
Sofort aufgefallen ist mir, dass ich keine Tracks mehr aus meinen bestehenden Playlisten in die Decks laden kann. :-(
Hat irgendjemand das gleiche Problem und kennt vielleicht sogar die Lösung?
geposted Sun 22 Sep 19 @ 7:36 pm
Hat nix mit der neuen Version zu tun. Wenn Tracks aus Playlisten nicht geladen werden können, stimmt entweder die Pfadangabe die in der Playlist hinterlegt ist nicht mehr, oder die Titel wurden verschoben bzw. entfernt
geposted Sun 22 Sep 19 @ 8:44 pm
Mal ne Zwischenfrage ....
in den Videos war zusehen das die Wave nach oben oder unten gelegt werden kann.
Kann man die Wave auch komplett wegschalten?
geposted Sun 22 Sep 19 @ 9:17 pm
also da die Optionen nur oben bzw. unten anbieten denke ich eher nicht ;-)
geposted Sun 22 Sep 19 @ 9:40 pm
NICE
geposted Sun 22 Sep 19 @ 10:35 pm
Im Performance Mode kannst du sie dir zumindest vertikal legen. Nimmt dann auch weniger Platz weg.
geposted Mon 23 Sep 19 @ 6:16 am
Aha, in die Richtung wegen dem Platz ging meine Frage ;-)
Okay, Danke!
geposted Mon 23 Sep 19 @ 6:35 am
Hallo Rob,
da hast Du Recht gehabt. Witzigerweise hab ich die letzte Playlist vom Stick angelegt, was ich nie mache.
Alle älteren Playlisten funktionieren auch mit der neuen Version einwandfrei.
Vielen Dank für Deinen Hinweis!
Bislang bin ich mächtig begeistert von der neuen Version, hab die halbe Nacht noch getestet und konfiguriert und alles läuft einwandfrei! :-)
geposted Mon 23 Sep 19 @ 12:55 pm
kann jemand sagen, wie man sich per shortcut durch die Waveformen klicken kann.
In der VDJ2018 ging das mit z.B. holding ? skin_pannel 'defaultwave' on : skin_pannel 'mirrorwave' on
In der 2020 Version funktioniert das leider nicht mehr
Danke schon mal vorab
geposted Mon 23 Sep 19 @ 5:03 pm
Kann Ich die Neue einfach drueber legen , also so installieren wie alle Updates bisher?
Also alle Dateien , im Docu Ordner lassen , Settings Datei , die alten Plugins , Skins und Einstellungen und Mappings?
Oder machts dann Probleme mit dem neuen?
Gruß Dani
Gruß Dani
geposted Mon 23 Sep 19 @ 6:39 pm
