new update changed my font and it only gives me 3 choices between fonts and still cant see it very well with my glasses on..
how can I make it bigger than BIG FONT?
geposted Mon 23 Sep 19 @ 12:56 am
settings browserFontSizeButtons on will give you + & - buttons down the bottom left
or you can pick a number directly with
settings fontSize
1.0 is standard size, try 1.4 maybe
settings fontSize
geposted Mon 23 Sep 19 @ 1:06 am
[sigh] Why do Atomix persist with doing this (change default on the quiet)?
The same happened with the CPU meter. Lots of posts asking why the meter wasn't showing anything. Oh, Atomix changed it, but you can change it back by doing this....
geposted Mon 23 Sep 19 @ 8:14 am
There was absolutely no need to change the font size buttons.
geposted Mon 23 Sep 19 @ 8:15 am
Need to bring back the font settings that VDJ pro 8 had. Not just small fonts & extra large fonts on VDJ 2020.
geposted Tue 24 Sep 19 @ 9:07 pm
Read the thread...
geposted Tue 24 Sep 19 @ 9:08 pm
In VirtualDJ 2020 settings, search for : browserFontSizeButtons .. thats it :)
