Hi, Is there any way to see if a track has had cue points set manually?
geposted Mon 23 Sep 19 @ 5:38 pm
Automix: Setting a 4sec fade out, makes the fade start before 4 sec before the Set out point. Is there a way to make the 4 sec fade start at the Outpoint?
For example, the out cue point is set, the next track cuts in on its in cue point, while the fade of the previous track begins.
geposted Mon 23 Sep 19 @ 5:59 pm
