Topic: Edit 2020 default Skin
How can I edit the 2020 default skin?
I can't find the new skin zip-file in the skin folder.
geposted Tue 24 Sep 19 @ 4:52 pm
djdad wrote :
https://virtualdj.com/manuals/virtualdj/settings/interface.html
Settings->Interface tab->Select the "Default"->Edit this skin from the right -side
Oh thanks, i have found it! :-)
Se puede exportar el skin de virtual dj 2020 para usar en la version de virtual dj 8.3?
Please post in English in the English-language parts of the forum.
What are you trying to achieve? Why would you want to use the new skin in the old version of the software?
It does work actually. I discovered this by chance when I ran my old build of VDJ 32 bit.
Of course the new 2020 specific parts won't work, but it runs.
