WHEN I MADE A NEW PLAYLIST I ACCIDENTALLY NAMED IT THE SAME NAME AS ONE OF MY OTHER PLAYLISTS AND IT DELETED MY OLD PLAYLIST AND REPLACED WITH THE NEW ONE. IN THE PAST IF I DID THAT IT WOULD JUST GIVE ME THE TWO PLAYLISTS WITH THE SAME NAME INSTEAD OF DELETING IT. IS THERE ANY WAY TO RECOVER THE ORIGINAL PLAYLIST?
geposted Fri 27 Sep 19 @ 2:34 am
No need to shout !
Only chance of recovery is with the underlying OS
Not sure about Mac but if you have windows, find the file right click and select properties and then look at the previous version tab. however this relies on shadow copy being turned on on your computer worth a try
geposted Sat 28 Sep 19 @ 7:54 am
Keep backups.
I'll say it again. KEEP BACKUPS!
geposted Sat 28 Sep 19 @ 8:05 am
